 Post subject: Some Winstep themes don't show up in list when installed...
PostPosted: Fri Jun 05, 2015 3:58 pm
This has happened several times, most recently with a theme called PlanB, from:
http://www.wincustomize.com/explore/winstep/218
I used Themes:Import, Winstep *says* it imported the theme, but it does not show up in the list... is there a maximum number of themes in the list?? Or am I doing something wrong?
 Post subject: Re: Some Winstep themes don't show up in list when installed
PostPosted: Fri Jun 05, 2015 4:02 pm
There is no maximum number of themes.
I don't have time now to check that particular theme, maybe it's missing a vital configuration file?
Also, remember that a theme made *only* for NextSTART, for instance, will NOT show up on WorkShelf's list of available themes.
PostPosted: Sat Jun 06, 2015 2:58 am
hmmm... interesting... how would I know if a skin is NextStart only, rather than a full Winstep skin? It doesn't have a .xtreme file, but the zip file *does* have .wsc, .wsr, .wst, .wsw ... which is comparable with other zip-distributed themes that *did* show up successfully.
PostPosted: Sun Jun 07, 2015 5:16 pm
.wst is the NextSTART configuration file, .wsw is the WorkShelf configuration file.
Check to see if the theme was properly imported into C:\Users\Public\Documents\WinStep\Themes\
PostPosted: Mon Jun 08, 2015 3:39 am
Interesting... no, it was not there... I extracted the theme into that Themes directory, and it immediately popped up in the Preferences:Themes list.
I wonder if the theme has a bug of some sort in it?? Although the theme now shows in the list, it does not actually render properly... Active processes all pop up in a button bar in the middle-bottom of screen, but task bar is not present. Also, the... ummm... bar that shows "main, desktop, recent, etc" is stuck to bottom of screen. (sorry I don't have the Winstep terminology down yet, program is still new to me!!)
I've seen this before on another theme, though I can't find it at the moment... I suspect these are older themes that aren't following some rule of current version.
PostPosted: Mon Jun 29, 2015 1:53 am
Wow, that is an oldie but goldie. From 2002. It's possible that it needs to be updated to current standards, but Jorge would know better than I. Plus there are quite a few skinners who see these posts (I hope they are still out there)
Users browsing this forum: Amazon [Bot], Apple [Bot], Google [Bot] and 49 guests
