 Post subject: Next start issues
PostPosted: Mon Jun 01, 2015 6:57 pm
Hi
I seem to be having an issue with Winstep. Using Nextstart, from time to time, the sys tray icons and clock will vanish. Sometimes I apply a new theme and it happens.
 Post subject: Re: Next start issues
PostPosted: Tue Jun 02, 2015 2:31 am
When that happens try pressing CTRL+F12 to bring up NextSTART Preferences and press the Ok button in the dialog.
Does that bring the systray/clock back?
PostPosted: Tue Jun 02, 2015 5:27 pm
Nothing happens, press ok, icons are still missing. Odd.
PostPosted: Tue Jun 02, 2015 7:10 pm
Ok, is the taskbar set to be always above other windows?
Also, if you set the taskbar to semi-transparent, can you see the systray *behind* the taskbar? Or it just disappears?
PostPosted: Tue Jun 02, 2015 10:44 pm
Hi
Tried both, same thing. Set to always be on top, nothing. Messed with the transparent setting, still no icons.
Thanks in advance.
PostPosted: Tue Jun 02, 2015 11:41 pm
Plot thickens...
This is going to be difficult because I never see that happen here. Can you spot some kind of a pattern when this happens? For instance, can you reproduce it 100% of the time or it seems like a random thing?
Users browsing this forum: No registered users and 75 guests
