 Post subject: Nexus: Weather Module
PostPosted: Thu Apr 09, 2015 8:31 am
Dear Winstep Guru's.
I have the same problem as in toppic http://forums.winstep.net/phpBB2/viewtopic.php?f=2&t=9144&start=15 or http://forums.winstep.net/phpBB2/viewtopic.php?f=2&t=9144.
But even if I follow the tips and code corrections, I still receive the "inalid location"-error.
What can be the problem?
Greetings and thank's for your support.
Diego
 Post subject: Re: Nexus: Weather Module
PostPosted: Fri Apr 10, 2015 12:09 pm
Additional Infomation:
OS ver. Win 7 Pro SP1
Nexus ver. 14.11.0999
PostPosted: Sat Apr 11, 2015 10:31 pm
Are you absolutely sure that you followed the directions correctly? If so, it definitely is caused by something specific to your PC.
Do you think it could be something related to the country you're in? To check if it is because of the area that you're in that retrieves the information, try getting the weather from other locations (including other countries) other than your local one and see what happens.
Users browsing this forum: Apple [Bot], winstep and 124 guests
