 Post subject: Extended desktop minor annoyance
PostPosted: Wed Mar 11, 2015 12:05 pm
Hi there,
First, thanks for making such an amazing product! It's completely replaced my windows Taskbar, and it's super sexy, so thank you.
But, I am running an extended desktop. The Nexus dock is running on my main monitor. When I do anything on my second monitor, and I move the mouse back over to my main monitor to access the dock, I have to click on the screen in order to make the dock appear. However if I'm only using my main monitor, all I have to do is drag the mouse to the bottom of the screen and the dock appears.
How can I solve this minor annoyance?
Thanks for your time
 Post subject: Re: Extended desktop minor annoyance
PostPosted: Sat Mar 14, 2015 9:15 am
Are you aware that you can run a dock on both Monitors at the same time? And they can contain different icons.
PostPosted: Sat Mar 14, 2015 1:56 pm
That's interesting, but it doesn't solve my issue. I don't want to have to use two docks.
Thanks anyway though!
PostPosted: Sat Mar 14, 2015 11:46 pm
Are you running any multiple monitor software programs, or have any Virtual Machines running?
Users browsing this forum: Apple [Bot] and 97 guests
