 Post subject: Mocing Winstep to new SSD
PostPosted: Thu Mar 05, 2015 5:22 am
G'day all,
I have been using and loving Winstep Extreme for over a year now without issue, however I now have a minor question that I hope someone here can help with.
My system currently has several different physical hard drives. One SSD and two large mechanical drives. I use the SSD as my main OS drive (C:) obviously, but to conserve space on it (it's only 256GB) I only install applications on it that are either very small, or will benefit from the increased access times.
When I installed Winstep I decided that it would probably not benefit from the faster access times so I installed it to one of my mechanical drives. Of course now I realise that this decision is why my windows takes so long to start.
I'd like to move my Winstep to the SSD (D: -> C:) but I'd prefer not to have reinstall and reconfigure it because it's taken me a while to get it "just right" and I'm not sure I can remember all the little tweaks I configured for it.
Can anyone tell me a relatively simple method of moving Winstep?
If not I'll just copy the entire Winstep folder structures from D: to C: and put links pointing to C: in place of the old (D:) Winstep folders, but I'm not sure this is the best solution.
Thanks for your help,
 Post subject: Re: Mocing Winstep to new SSD
PostPosted: Thu Mar 05, 2015 7:21 am
There's a backup/restore function within Winstep.
Now I can't tell you if it will work if you uninstall then reinstall on a different drive, especially regargind icons paths or such things.
At worst, I think you can try, and if it fails, reinstall back as it was, and then try the symbolic lnks you were thinking about.
Regards.
PostPosted: Thu Mar 05, 2015 10:36 am
It'll work.
On a different note... I've got a 120GB Samsung 840 Pro and half of it is empty... and I've got everything in it, including Visual Studio and MatLab. What the hell are you installing (and it's **only** 256GB)???
PostPosted: Fri Mar 06, 2015 2:31 pm
Thanks for the help. I've got it all working now.
As for what I have installed, allowing for the OS which becomes more bloated the longer its on (thanks MS) I have mostly my games including Skyrim and all its associated mods (and I've modded the hell out of it) so that is what is taking up most of the space.
Users browsing this forum: Apple [Bot], Google [Bot], Reborn and 22 guests
