 Post subject: Configuring Sub-Docks
PostPosted: Tue Jan 20, 2015 5:20 am
I just purchased Winstep Nexus Ultimate for my PC (running Win 8.1, 64 bit).
I have pretty much configured it exactly as I like except for the sub-docks. Those, I have not been able to figure out how to modify. Any help would be greatly appreciated.
So you know, what I am trying to do is set the sub-docks to expand horizontally rather than vertically, as they do now. I'm also hoping there will be other options, i.e. changing the background of the sub-docks, other ways to expand them (other than horizontal or vertical), etc. But for now, I would love to at least have them expand horizontally.
Again, any help from the community is greatly appreciated! Thanks in advance.
 Post subject: Re: Configuring Sub-Docks
PostPosted: Tue Jan 20, 2015 5:53 am
Open the Dock Properties panel for the dock whose sub-dock behavior you are trying to change (i.e.; right click dock control icon -> select Dock Properties) then go to the Behavior tab.
Click the Sub-Docks button. In the dialog that pops up, you will find several options related to sub-docks, including how they open and what opening animation to use.
You cannot change the theme/background of a sub-dock, however, it will always be the same as the parent dock.
PostPosted: Tue Jan 20, 2015 8:11 am
I'm not sure how I missed that, but clearly I did. Thank you very much. Worked like a charm! :-)
PostPosted: Tue Jan 20, 2015 8:16 am
The software is very configurable, so lots of options to find and play with. ;-)
Guess that is part of the fun. :)
Users browsing this forum: Google [Bot], GPT [Bot] and 54 guests
