 Post subject: Mirror docks on multi-monitor configurations
PostPosted: Wed Dec 31, 2014 12:15 pm
Is it possible or could it be to have a duplicate dock(s) appear on a second monitor when two monitors are being used?
 Post subject: Re: Mirror docks on multi-monitor configurations
PostPosted: Thu Jan 08, 2015 5:34 am
If you are using either Nexus Ultimate or Winstep Xtreme, you can have multiple docks. Then you can use the built-in Dock and Shelf Management features to duplicate your main dock and set it to appear on your secondary monitor.
Once created as a copy of your main dock, it will be an independent dock, however, so any changes made to the primary dock will NOT be reflected in the second.
Users browsing this forum: GPT [Bot] and 53 guests
