 Post subject: Winstep Xtreme Updates
PostPosted: Tue Dec 02, 2014 4:51 am
Hi Jorge. There were a couple of updates that I installed (yesterday) and friends of mine (today) that also have Winstep Xtreme.
We would like to know what was added to the updates. The more updates the better! :D
 Post subject: Re: Winstep Xtreme Updates
PostPosted: Tue Dec 02, 2014 5:11 pm
Check the Release Announcement on the Winstep web site, list of changes is at the bottom. There is always the history files too. :D
PostPosted: Thu Dec 04, 2014 2:39 am
Thanks for the updates! I tried out the new Internal Commands. Pretty cool! I would like to know if there is a way to toggle back and forth from minimizing them to the toolbar (BTW I'm using the Windows toolbar in Win7) to bringing up the folders to show on the Desktop?
Currently once bringing up the folders manually one by one, I have to do the same to minimize them by clicking on the - sign of each folder.
I set the Internal Command to bring up the folders with Hotkey Alt + A for "Show windows stacked". It won't pull up the folders that are minimized. I also tried out resetting it by switching the Internal Command to "Cascade windows" or "Show windows side by side". It will only reset if the folders are showing on the Desktop and not minimized.
I also tried it by opening several instances of my browser and the same thing goes for the browser as well.
Am I doing something wrong?
Users browsing this forum: Apple [Bot], GPT [Bot] and 59 guests
