 Post subject: Transparency in Windows 8.1
PostPosted: Mon Oct 13, 2014 9:14 pm
Hello, I was wondering if Winstep Ultimate's dock transparency works with Windows 8.1. The transparency slider does nothing on my rig, whether I set it to 0 or 100...
Can somebody clarify this?
Thanks, y'all.
 Post subject: Re: Transparency in Windows 8.1
PostPosted: Thu Nov 27, 2014 12:10 am
Did you hit "Apply" after you made a change? It doesn't show anything until you hit apply.
On my Win 8.1 update machine, I can set a transparency of 0% (zero) or 100%. Anything else just turns a lighter color with no transparency.
PostPosted: Thu Nov 27, 2014 2:49 pm
Oooh I fixed this a while ago, thanks for your help though. I can't even remember correctly but I think there was something wrong with my Windows configuration.
Users browsing this forum: Amazon [Bot], Google [Bot], GPT [Bot] and 86 guests
