 Post subject: How to enlarge Winstep Workshelf
PostPosted: Thu May 15, 2014 4:58 pm
Hi guy's,
I want to enlarge the workshelf in order to display all the tab names but I haven't see how to do that. I don't want to enlarge it to the whole screen with(span the full screen), just around 100-200 pixels. Is that possible?
Cheers, Lecra
 Post subject: Re: How to enlarge Winstep Workshelf
PostPosted: Thu May 15, 2014 5:12 pm
Expand the Shelf and move the mouse over either the left or right edges. The cursor should turn into a double arrow at some point, then you can just click and drag to enlarge/shrink the Shelf in that direction.
PostPosted: Thu May 15, 2014 6:14 pm
Hi Jorge,
Thank you for your quick answer. What do you mean with 'expand'? In the configuration mode? I tried everything but i can't see the cursor changing in order to enlarge the frame.
KR, Lecra
PostPosted: Thu May 15, 2014 6:36 pm
The Shelf is probably locked.
To unlock it:
Goto Shelf Properties, Tab Behavior and below More Options uncheck the entry Prevent shelf from being moved by dragging with the mouse pointer.
PostPosted: Thu May 15, 2014 6:38 pm
Henk, I got it just after have written the Thread..
To unlock it:
Now I have another issue. All the icons in a TAB are aligned at the left side. It is possible to change the alignment, perhaps centered?
Many thanks people for your support.
KR, Lecra
PostPosted: Thu May 15, 2014 6:52 pm
Nope, not possible, sorry.
PostPosted: Fri May 30, 2014 7:48 pm
well, you could "cheat" by creating as many dummy entries on the shelf as needed to center the existing icons :-)
Users browsing this forum: Amazon [Bot], Google [Bot] and 43 guests
