 Post subject: Always on-top in fullscreen
PostPosted: Fri May 30, 2014 6:16 am
I'm having an odd issue that I can't seem to figure out.
I run Winstep with the always on-top option selected so that when I move my mouse cursor over the icons that they will expand over the existing maximised windows without the delay associated with if the option is off. This works perfectly.
However, when I run some applications in Fullscreen mode (Youtube videos especially) then it will still remain on top.
Is there a way to set winstep to always be on top of maximised windows but not in fullscreen videos such as youtube videos?
 Post subject: Re: Always on-top in fullscreen
PostPosted: Fri May 30, 2014 6:27 am
Sorry to say, the Adobe dudes must have changed something in the code, because this is a relatively recent occurrence.
From what I know, you can't do it for the time being.
I hear it's being worked on, though...
PostPosted: Fri May 30, 2014 6:30 am
*cries quietly inside*
Thanks for the response. Guess I'll just wait for the update. Not a major trainsmash. Will just hide the bar with the nexus icon I guess :)
Users browsing this forum: Google [Bot] and 107 guests
