 Post subject: Ctl-Alt Left-click is acting like middle click
PostPosted: Fri Oct 05, 2007 6:07 pm
Is there any reason why a hot spot that is to be triggered by a "middle click anywhere" is also being triggered by Ctl-Alt Left-click? My application uses ctl-alt left click for a certain function and it is doing the correct action PLUS bringing up my NextStart Start Menu, set to hotspot 18 w/middle click anywhere.
PostPosted: Sat Oct 06, 2007 1:49 pm
Yes, Ctl-Alt Left-click is used to emulate middle clicks on two button mice.
To disable that, open NextSTART Preferences, go to Global Preferences and click on the Mouse Settings button. In the dialog that pops up, un-check 'Emulate Middle Click'.
Users browsing this forum: Bing [Bot] and 36 guests
