 Post subject: Weather Module
PostPosted: Sun Mar 02, 2014 3:11 pm
When will this be addressed?
 Post subject: Re: Weather Module
PostPosted: Sun Mar 02, 2014 3:40 pm
When will what be addressed?
PostPosted: Sun Mar 02, 2014 3:51 pm
The title of the post is "Weather Module". It still does not work.
PostPosted: Sun Mar 02, 2014 3:53 pm
It works just fine here. Are you sure there isn't some other problem with your settings, configuration or firewall?
PostPosted: Sun Mar 02, 2014 4:04 pm
After fifteen years?
PostPosted: Sun Mar 02, 2014 4:49 pm
Are you saying, you've been using the same operating system on the same computer for the last 15 years?
In any case, my weather module is working and after I checked, it's receiving its feed from MSN Weather. The METAR URL has changed from what Winstep is using and even though I checked, the new URL is a bit strange.
However, the Weather.com feed is working as well, at least for two locations I've tried.
Are you sure you've updated to the last version of Winstep? I remember there were issues with Weather.com changing its service availability, but Jorge had released a build to fix exactly that.
PostPosted: Mon Mar 03, 2014 12:55 am
Gregory2001. I've posted about this topic on several occasions and couldn't find a solution. However, very recently I figured out something that might work. I have to use it every now and then when for some unknown reason the weather module stops working. Try this workaround.
Switch to a different city that works (preferably one close enough so the disparity in temperature is minimal) and leave it there for a week or so and then switch it back. It should work again with the city of your choice. Repeat as needed. BTW, you can check in 3 or 4 days but it might not work.
Please do us a favor by reporting back with the results. That way we will know if it's just a fluke on my PC or if this is a viable workaround for everyone although temporary in nature since something causes it to stop working periodically.
PostPosted: Mon Mar 03, 2014 1:41 am
Could you also post, if it works, which service it uses to retrieve weather data?
As I already mentioned, mine indicates "NOAA / MSN".
PostPosted: Mon Mar 03, 2014 2:44 am
Thanks, Windy. I've done that and it does work temporarily but there should be no reason why we have to do that.
Users browsing this forum: Amazon [Bot], Apple [Bot], Google [Bot] and 59 guests
