 Post subject: Newbie questions
PostPosted: Wed Dec 18, 2013 8:29 pm
Hi :)
Yesterday I installed the latest version and I have some questions:
  • - How can I define my own design?
  • - I added a new category with the "Start Menu Organizer Pro", but these categories don't show up in the start menu at all. Where are they?
  • My taskbar has a little gap between it and the bottom. How can I move the taskbar to the real bottom of the desktop?
 Post subject: Re: Newbie questions
PostPosted: Thu Dec 19, 2013 1:33 pm
when you create your own categories in startmenu organizer they will not show up on the startmenu until inside startmenu organizer you drag at least one item into each one and save it.
PostPosted: Thu Dec 19, 2013 8:54 pm
I still don't get it. Only the menu created with the menu editor appears on the start button. I really don't know what this Start Menu Organizier is for. And the documentation doesn't help at all.
PostPosted: Thu Dec 19, 2013 10:26 pm
skagon help please
PostPosted: Fri Dec 20, 2013 1:11 pm
The Start Menu Organiser (at least as far as I understand it) is a tool that allows you to... well... organise the "all programs" sub-menu. Instead of dragging and dropping icons, which can get really tedious if you have a lot of manipulation, it allows you to create your own "folders" and move the current shortcuts and folders easily. It will not change anything else in the Start menu and it has nothing to do with themes either.
Obviously, you will have to populate the "categories" with shortcuts and/or folders.
Users browsing this forum: Google [Bot] and 23 guests
