 Post subject: CPU High usage
PostPosted: Sun Dec 08, 2013 1:32 pm
Hiya I run wincustomise software an winstep extreme both at the same time...I am running windows 8.1....my cpu is running at 32% to 50% at all times...my computer itself is making beeping noises...it only startyed happening once I installed Winstep extreme....in task manager the wmi.provider host is using the most cpu usage...is it anything I need to be concerned about...and if yes how do I rectify....thanking you in advance....Smiler
Users browsing this forum: Google [Bot] and 27 guests
