 Post subject: How to make sub-dock horizontal?
PostPosted: Tue Nov 05, 2013 2:15 am
Hi all. As title says, how do I make a sub-dock horizontal in orientation, just like the weather app's sub-dock?
Using search, it appears this question has been asked before, but no answers given. :oops:
I'm using Nexus Ultimate.
Jim
 Post subject: Re: How to make sub-dock horizontal?
PostPosted: Tue Nov 05, 2013 11:07 pm
Right click on dock
Select Dock Properties
Click on Sub-Docks (bottom right)
Select Always horizontal (or any other option you want).
Or (alternatively):
Use Workshelf Preferences
Select appropriate dock
Select Tab Behavior
PostPosted: Tue Nov 05, 2013 11:23 pm
Henk1956 wrote:
Right click on dock
Or (alternatively):
Select Tab Behavior
Hi. Thanks for your help. I used the first option you gave me. One thing missing from it that had me confused for a while was you have to select the Behaviour tab to find the Sub-Docks option. It should be like this:
    Select behaviour Tab
Thanks again for you input! :D
Jim
Users browsing this forum: Google [Bot] and 23 guests
