 Post subject: Winstep Recycle Bin Not Responding
PostPosted: Mon Jul 15, 2013 5:09 am
Guys, I have to restart Winstep to get the recycle bin to update to an empty state. I empty it but it still shows the full state.
Opened, the bin is empty, but shows full.
Only a Winstep restart will fix it, every time.
Any ideas?
Windows 7 64 bit.
Jim Dillard
 Profile YIM
 Post subject: Re: Winstep Recycle Bin Not Responding (Solved)
PostPosted: Mon Jul 15, 2013 6:16 am
Silly me. I found the setting...lol. I had animations turned off for thr recycler module...duh. :oops:
I dunno how it got set that way.
Jim Dillard
 Profile YIM
PostPosted: Mon Jul 15, 2013 1:45 pm
Jim,
If you've deleted something that requires a reboot for the system to really dispose of it, the Windows Recycle bin shows empty, but the Winstep icon shows full.
Good luck,
Grouch
Windows 10 Pro[x64]
Nexus Ultimate 20.10.1154
Antivirus: Windows Defender
PostPosted: Tue Jul 16, 2013 10:13 pm
Any ideas?
Windows 7 64 bit.
Just so you know, if you use a program such as CCleaner BEFORE manually emptying (right-click > Empty recycler) the recycle bin, the same thing will happen, at least with the WinstepSamples theme.
Glad you found out what was causing the issue.
PostPosted: Wed Jul 17, 2013 1:53 pm
i can verify from experience what windy said about ccleaner.
Users browsing this forum: Apple [Bot] and 74 guests
