 Post subject: Systray off screen
PostPosted: Mon Jun 03, 2013 8:44 am
On a laptop using the latest version of Xtreme, with only Nextstart running.
I've got a floating systray in the lower RH corner of the screen. I frequently dock with other higher res monitors, and the systray holds it's absolute position in x,y terms (so when I dock, the tray isn't in the corner, but is visible). This isn't a problem, I can move it to where I want it to be. The problem is moving the other way. If I forget to move it before I undock, then when I revert back to the lower res laptop screen the systray sort of disappears off screen (I say sort of as it seems to adjust on the y-axis, but not the x-axis). I can generally get it back by switching the systray direction to get the button on screen, but its a nuisance.
Is there any way of forcing a 'position systray in bottom RH corner of primary monitor'? I thought there used to be, but I can't find anything to do this now.
 Post subject: Re: Systray off screen
PostPosted: Thu Aug 22, 2013 10:53 am
I have checked here a few times in the past couple of weeks and I notice that the moderator of this site has allowed you to constantly post spam and not removed it so I'm wondering if support will be lacking or the products inferior. I haven't used the products that much yet so I'm not sure if they have any bugs or not.
Subscribe for pass4sure coupon and ISC or University of Oxford and wikipedia
PostPosted: Thu Aug 22, 2013 9:04 pm
Rosie, if you can point out those posts for me, or just press the "report" button next to each, I promise, I'll take care of everything as soon as possible.
Cheers!
PostPosted: Thu Aug 22, 2013 9:06 pm
Not sure why you think I've been posting spam.
On the other points - there is currently a temporary hiatus in support from the software's author while he recovers from an accident (at least I hope its temporary). The software itself is very stable - I use it constantly on all my PCs, including my primary work PC. There are occasional annoyances, like the one I've posted about, and like any software some issues crop up with specific system/software set-ups but from looking at the forums these don't tend to be serious.
PostPosted: Mon Aug 26, 2013 10:35 pm
temporary is a EXTREME understatement.
PostPosted: Tue Aug 27, 2013 6:37 pm
I'm in a 'glass half full' kind of mood...
Users browsing this forum: GPT [Bot] and 28 guests
