 Post subject: Auto-Hide isn't hiding inverted tabs when docked
PostPosted: Mon May 06, 2013 3:19 am
I can't hide inverted tabs when the shelf is docked(top/bottom). It hides the tabs perfectly when floating-inverted. Any help would be appreciated.
I would also like to remove the shelf's drop shadow. Not the icons drop shadow but the shelf's. If someone could at least shove me in the right direction I could try to figure it out on my own. Thanks
Users browsing this forum: GPT [Bot] and 28 guests
