 Post subject: Objectdock Backgrounds with NEXUS
PostPosted: Mon Sep 24, 2007 3:49 pm
Can I use Objectdock backgrounds with Nexus? If yes, How?
PostPosted: Mon Sep 24, 2007 4:02 pm
Yes you can. You can also use other dock's backgrounds (RocketDock, YZ Dock, etc...). This is how to do it:
Open
c:\program files\winstep\nexus\backgrounds\
in an Explorer window. The backgrounds should be stored in sub-folders of that folder, i.e.; suppose you have a OB theme called 'Eminence', the Eminence OD theme files should be unzipped into the
c:\program files\winstep\nexus\backgrounds\Eminence\
folder. Now right click on the NeXuS control icon of your dock and select 'Dock Style Editor' from the context menu. In the Dock Style Editor dialog select 'Backgrounds' from the pull up menu - you should now see the OD backgrounds you just stored under the \NeXuS\Backgrounds folder.
Note that, if you have more than one dock, you will need to apply the Dock Style Editor procedure to each of your docks.
PostPosted: Mon Sep 24, 2007 4:15 pm
Thanks. I really appreciate that. :D
Users browsing this forum: Amazon [Bot], Majestic-12 [Bot] and 42 guests
