 Post subject: Workshelf & Icon Packager
PostPosted: Sat Apr 06, 2013 11:51 am
Whenever I add a new item to Workshelf, instead of using the provided icon it presents a default blank papersheet icon. Every time. There is a way around it by using the "change icon" function but it's a nuisance and in any case doesn't work in all cases.
I know this is due to the combination of Icon Packager and Workshelf because it doesn't occur when IP is uninstalled.
Does anyone else use these 2 packages, and do you have the same problem ?
Vlodec
 Post subject: Re: Workshelf & Icon Packager
PostPosted: Sat Apr 06, 2013 12:37 pm
if you want custom icons you're better off going to www.virtualcustoms.net. icon packager has more than it's share of problems.
PostPosted: Thu Apr 11, 2013 12:06 am
if you want custom icons you're better off going to http://www.virtualcustoms.net. icon packager has more than it's share of problems.
Thank you, but I like Icon Packager and as this is the only problem I have with it, and it's a minor one, I prefer to stick with it and solve the problem itself. Thanks again.
Vlodec
Users browsing this forum: GPT [Bot], Majestic-12 [Bot] and 32 guests
