 Post subject: drag and drop problems
PostPosted: Fri Mar 15, 2013 8:55 pm
hi. im a little dissapointed. cannot understand the system of the nexus bar.
if i drag and drop a shortcut, of a game in this case, its creating a shortcut on the bar, ok. then i delete the original shortcut on my desktop......but then: its not working anymore in the taskbar...
is there another way to fill a bar via DRAG AND DROP like the rocketdock is doing ?
 Post subject: Re: drag and drop problems
PostPosted: Fri Mar 15, 2013 9:01 pm
Too be honest you could just drag the shortcut to a directory you never visit, and then drag it too the dock without removing the original shortcut.
PostPosted: Fri Mar 15, 2013 11:35 pm
Theoretically, shortcuts should resolve to the linked executable. Those shortcuts you're having the problem with, must be those "special" shortcuts that link to something like registry keys or whatever...
Why don't you try and drag-drop the .EXE itself?
PostPosted: Sat Mar 16, 2013 4:50 pm
hi amiga and skagon. i did amigas way :-) i have lots of directories with a shortcut in it. makes nosense to me since im a programmer too, but anyway, its a complex system
and this are 90% steam shortcuts.......
hope for a upgrade soon, its complicated to create a fast connection. rocketdock is working like a charm. anyway
this folders are now on the bottom bar.........works :mrgreen:
thank you alot for answering here! you roxx
Users browsing this forum: Apple [Bot] and 55 guests
