 Post subject: How to use animated icons correctly
PostPosted: Mon Feb 04, 2013 4:32 pm
Animated Icons:I unrared the folder to a location.When I drag "n" drop an icon to the bar,say firefox for instance,then open it,it will open the containing folder where there were unzipped to.If i swith the target line to firefox.exe folder it switches the icon to the default firefox icon.Any quick pointers as to whats going wrong here.LOVE THE PROGRAM BTW......thnx
NVM I read the readme and it's all clear now.
 Post subject: Re: How to use animated icons correctly
PostPosted: Mon Feb 04, 2013 4:50 pm
I'm not sure if I fully understand, but you should try it this way.
1. Find the folder, or program executable (i.e. Firefox shortcut from the Desktop or from (All) Programs) and drag that to the Dock.
2. Right-click the icon > Dock Entries Properties > Change Icon > Browse > and go to where the Animated Icon is that you want to use and click on it. > Ok > Ok.
Let me know if it worked out for you.
Users browsing this forum: Amazon [Bot], GPT [Bot] and 42 guests
