 Post subject: Rightside Dock pushes active screen
PostPosted: Thu May 30, 2013 3:20 pm
Hi, my name is Iben and first of all, I hope that I'm posting this in the right area.
I've currently had some troubles with my Nexus Dock. I use the free version and it's really amazing and perfect for what I want.
I tried to get it in the screen. I have two monitors and whenever I'm using a program that's on the monitor with the dock, it "pushes" the active program each 5 seconds. The active screen gets "pushed" to the left, creating the gap I pointed out, and then goes back, with the circle starting over again.
Is there anyway I could fix this ? It's quite annoying when you're painting stuff and your screen moves so you mess up :/
Thanks in advance !
Users browsing this forum: No registered users and 36 guests
