 Post subject: Winstep dock problem.
PostPosted: Sun Dec 09, 2012 2:37 am
Hello,
I need your help in this situation:
Sometimes, in spite of Winstep is configured to be under any Windows to avoid disturbing the active Windows software, the Winstep software don't work in this mode and i can't hide the dock.
Thank you!
 Post subject: Re: Winstep dock problem.
PostPosted: Sun Dec 09, 2012 10:18 am
Oh yes, i have seen this behaviour and it can get quite annoying. Although i only saw it when i was using the Explorer shell (i use emergeDesktop).
Sometimes i fixed it by selecting and deselecting the options you have there; always on top, always under, same as other, untill it fixes it)
PostPosted: Sun Dec 09, 2012 2:43 pm
Hello,
Thank you very much for your ideas. I will aplly what you have said to me.
That's a great idea so reset this part of Winstep setup.
This issue happend with many software.
Thank you!
PostPosted: Tue Dec 11, 2012 9:29 am
Does it only happen with Chrome as the foreground window? Google always enjoyed doing stuff in a non-standard way and then unexpected issues like this happen.
PostPosted: Wed Dec 12, 2012 2:20 am
Hello Jorge,
No, it happend with a lot of programs. For example i could see it with a Windows folder, Google Chrome,etc.
Thank for your help.
Users browsing this forum: Majestic-12 [Bot] and 35 guests
