 Post subject: Start menu
PostPosted: Sun Dec 16, 2012 4:07 am
Can I put a short cut for the start menu in the shelves? If so how. thanks funnnyfarm
 Post subject: Re: Start menu
PostPosted: Sun Dec 16, 2012 1:46 pm
why would you want to when all you have to do is press the win flag key to bring up the startmenu.
PostPosted: Sun Dec 16, 2012 4:40 pm
I want to keep the task bar hiden
PostPosted: Sun Dec 16, 2012 4:57 pm
if you hit the win flag key it only shows the startmenu and not the taskbar.
PostPosted: Mon Jan 07, 2013 8:40 pm
As long as you are NOT running Windows 8, right click on the Shelf, select Insert New Shelf Item -> Internal Command -> Desktop -> Start Menu.
PostPosted: Tue Jan 08, 2013 1:47 pm
Hi Jorge, I read this thread and didn't remember seeing this feature in WorkShelf. I checked and my memory was confirmed.
Did you and the OP (funnnyfarm) mean a Dock instead of a Shelf?
PostPosted: Tue Jan 08, 2013 2:35 pm
No, I did mean the Shelf. However, I failed to mention that you can only add shortcuts (such as the Start Menu Internal Command) to *Regular* tab types in the Shelf. It *won't work* if you try to add it to a tab displaying the contents of the Control Panel or a folder in your hard drive, for instance.
PostPosted: Tue Jan 08, 2013 4:31 pm
Thanks for the info. It's good to know. However, what my main question was is your directions.
I don't see this in WorkShelf at all. I only see this in the Dock. Is something missing?
PostPosted: Tue Jan 08, 2013 4:46 pm
Do you still have a 'Main' tab on the Shelf? That is an example of a 'Regular' tab type (one you can add shortcuts to just like in a dock). If so, right click any item/shortcut in it and let me know if you see a 'Insert New Shelf Item' option in the context menu that pops up.
Also, make sure you are running v12.2. :)
PostPosted: Tue Jan 08, 2013 8:36 pm
Ah, I see what the problem was. I didn't understand your directions. I took it to mean to right-click on the Shelf. I didn't know it has to be done on an item in the Main tab.
I have never used that tab. I mainly use the Desktop tab and the Control Panel tab which are both awesome!! There is so much to Xtreme! :lol: Now it made me think about the poster that was complaining that Winstep Xtreme has too many features. That was the first time I'd ever heard of such a thing.
PostPosted: Tue Jan 08, 2013 8:40 pm
Well, the thing is, not all tabs in the Shelf are alike, the same way the Control Panel/My Computer folders are not the same as regular folders in your hard drive - you can't put shortcuts in an Explorer Control Panel folder either.
Likewise, some tabs types in the Shelf are special and should not/cannot be used to place shortcuts in them.
Users browsing this forum: No registered users and 33 guests
