 Post subject: Hotspots and Windows 8
PostPosted: Thu Dec 06, 2012 8:01 pm
Windows 8 occupies the four corners of the screen.
NextStart has the top left and top center.
Before I start stringing Winstep hotspots all over, will one take precedence over the other or conflict? Is it dependent on which program has the focus?
Mist
 Post subject: Re: Hotspots and Windows 8
PostPosted: Fri Dec 07, 2012 4:52 am
Winstep hotspots will work regardless of Windows 8's hotspots. What will happen if you overlap hotspots is that you will have both Windows and Winstep responding to the activation of the same hotspot.
PostPosted: Fri Dec 07, 2012 4:56 pm
Kind of what I thought. Pesky Windows.
Thanks, Jorge.
Users browsing this forum: No registered users and 55 guests
