 Post subject: Not bright question of the whatever
PostPosted: Thu Dec 06, 2012 7:49 pm
Month - might need space. :?
Is it possible to copy in previous backups for workspace and nexus?
The dumb question: difference between workspace and nexus - what goes where?
Not my brightest day.
Thanks,
Mist
 Post subject: Re: Not bright question of the whatever
PostPosted: Fri Dec 07, 2012 4:54 am
I think you mean WorkShelf, not 'Workspace', right?
I'm not sure I understand your question, though. Once you have Xtreme installed, you should forget about any previous Nexus backups (assuming you were running Nexus before installing Xtreme, of course).
PostPosted: Fri Dec 07, 2012 5:01 pm
You're correct.
Solves that. Was looking for an easy way out. :wink:
Thanks.
Mist
Users browsing this forum: GPT [Bot] and 54 guests
