 Post subject: Multiple Weather Modules
PostPosted: Tue Oct 23, 2012 4:21 am
I would like to have multiple weather modules to check the weather in several locations that appeal to me. Is it possible to have more than 1 weather module and if yes how do you set it up. Thank you for any help. I am using Winstep Extreme.
 Post subject: Re: Multiple Weather Modules
PostPosted: Tue Oct 23, 2012 8:17 pm
No, sorry, at the moment you cannot 'clone' modules and have different modules with different settings. If it's any consolation, it is on the to-do list.
PostPosted: Tue Oct 23, 2012 9:58 pm
Thank you for the reply, when it is it's turn on the to do list, then it will be there. Till then I can always just look it up. Again thank you for your response.
Users browsing this forum: GPT [Bot] and 52 guests
