 Post subject: Weather Module will not retreive any state or city informati
PostPosted: Thu Oct 11, 2012 12:29 pm
My weather module has stopped working. I am using Workshelf v12.02.1037. I have tried multiple states and city and all receive the same error. I am attaching screen shots of my Weather Module setting page, the error message received when I click on the Get Weather link and the URLs in the Advanced windows. I have never changed anything in the Advanced windows.
 Post subject: Re: Weather Module will not retreive any state or city infor
PostPosted: Thu Oct 11, 2012 1:45 pm
check the settings in you firewall. you could of accidentally changed something, one of it's updates could of changed something, or it could be that the maker of you firewall deliberately blocked the connection.
this is for jorge:
i noticed that it ask "how often would you like to update weather conditions?". it should be "when would you like to update weather conditions?". also i don't get anything for portland, portland international airport, but i do for portland, portland-hilsboro air port. the difference between the two can be as much as 8f.
EDIT:
started new thread here, so as not to get off op's topic.
viewtopic.php?f=2&t=8496
Users browsing this forum: Amazon [Bot] and 46 guests
