 Post subject: clock.wav saved ?
PostPosted: Thu Oct 04, 2012 12:11 am
where is the clock.wav saved ? i would like to replace it with one of my own ... thx
 Post subject: Re: clock.wav saved ?
PostPosted: Thu Oct 04, 2012 1:29 am
As far as I'm aware, there is no "clock.wav". What exactly are you looking for?
PostPosted: Thu Oct 04, 2012 6:18 am
the (.....wav) file that is the sound of the clock "the dong sound". i want to replace it.... so where is it saved? i have replaced one rebooted and the old sound is still playing.......
PostPosted: Thu Oct 04, 2012 1:41 pm
looks like
c\users\public\public documents\winstep\themes\Voce Femminile (ITA)
and
c\users\public\public documents\winstep\themes\Voce Maschile (ITA)
i'm assuming from the look of it and the sound of it mine is in portuguese including the folder names even though everything else in winstep seems to be in english like it should be. i downloaded this through the winstep site from cnet, so i should of gotten an all english version. this copy is less than 3 months old. and before someone ask yes i clicked on some of the wav files in the folders and they are not in english.
PostPosted: Thu Oct 04, 2012 3:13 pm
The "dong" sound, which is *not* related to the time announcement, is located (assuming your system drive is C) in:
C:\Users\Public\Documents\Winstep\Themes\WinstepSamples\wsChime.wav
Of course, instead of replacing the original file, you could always go to the sound settings in the preferences and simply change the "Clock Chime" sound file to anything you want.
Cheers!
PostPosted: Thu Oct 04, 2012 11:08 pm
thank you done, i was looking under the wrong preferences
Users browsing this forum: Google [Bot], GPT [Bot] and 68 guests
