 Post subject: Win 7 aero bug
PostPosted: Thu Sep 20, 2012 10:03 am
Hi, well straight to the thing, while using nexus sometimes win theme looks like classic theme with aero disabled.
This occurs when window is maximized, when i restore it down, theme gets normal.
Also sometimes when window is maximized also the bottom line of the window jumps up and down in a about 2 pixel radius.
Note that this occurs only when window is maximized.
I'll post a screen shot for the theme problem, i can't rec a video for the other problem.
Software version is: 12.02
Win taskbar is hidden, nexus is set to dock down, it's not always above, it's set to normal, and prevent maximized windows from overlaping the dock opction is on.
Screen shot: http://postimage.org/image/5883uq8pn/
Hope i gave you enough info, regards.
 Post subject: Re: Win 7 aero bug
PostPosted: Thu Sep 20, 2012 12:31 pm
your nexus dock looks fine there. i would say it's either a 3rd party theme from virtualcustoms, your comp is not patched correctly for 3rd party themes, or some 3rd party app is causing the problem. first i would back track to when it first started happening and see what changed. second i would post a thread on vc about the prob, cause probs like yours almost always have to do with themes.
PostPosted: Thu Sep 20, 2012 6:26 pm
I don't have any custom theme or anything like that except nexus. I was just browsing that website, I don't use any of their things. I think this is just problem with chrome so far I noticed.
PostPosted: Thu Sep 20, 2012 6:28 pm
And I forgot to say that problem started when nexus was installed. I didn't have any 3rd party software before or after nexus.
PostPosted: Sat Sep 22, 2012 7:15 pm
Well, that should give you your answer, no? :wink:
The Google guys like to do some things in a non-standard way (for instance, previously there was a Chrome specific issue related to maximized Chrome windows being given the same properties as full screen windows), and then things like this happen.
See if you can reproduce the problem with other maximized applications then please let me know.
PostPosted: Sun Sep 23, 2012 7:19 pm
The problem is only with chrome, that's not a big deal, I can live with that. Cheers.
PostPosted: Mon Sep 24, 2012 4:09 am
Thanks! :D
If I run across this problem with Chrome in the mean time I'll see what I can do to solve it.
Users browsing this forum: Apple [Bot] and 56 guests
