 Post subject: Windows taskbar
PostPosted: Fri Sep 14, 2012 9:12 am
I seem to be having problem with win taskbar. I unchecked allow nextstart..in preferences-taskbar and checked keep win taskbar visible. What that does is close winstep taskbar but win taskbar is invisble or transparant. I tried to reset to installation defaults but no go for win taskbar. Any solutions?
 Post subject: Re: Windows taskbar
PostPosted: Fri Sep 14, 2012 12:15 pm
first thing to try is see if you set it to autohide. did you bump the screen edge you have it on?
PostPosted: Fri Sep 14, 2012 1:17 pm
Yes, tried that.
It seems it has place reserved for it but it doesnt show.
Look at these pics:
Autohide on, shelf is on the bottom
Autohide off, shelf is positioned higher.
p.s.:Made shortcut to taskbar, so i can see its properties.
PostPosted: Fri Sep 14, 2012 1:36 pm
mgermo wrote:
Yes, tried that.
Look at these pics:
o.k. that's going to be something with windows itself. i'd suggest going to sevenforums and starting a thread there.
PostPosted: Fri Sep 14, 2012 3:11 pm
When I quit winstep win taskbar is normal. It must be a setting in workshelf, because if I open nextStart, i have both taskbars, but when i open workshelf win taskbar is gone, never to be seen again :p
PostPosted: Fri Sep 14, 2012 3:49 pm
i just went through the shelf prefs and found nothing, i also before my previous post went through the nextstart prefs and found nothing.
PostPosted: Fri Sep 14, 2012 6:30 pm
There is another hide win taskbar under dock settings (which is a part of shelf) i believe. After i created a dock (which at some point i had and settings stuck around) and then reset everything under troubleshooting, i got win taskbar back.
Thanks for the help.
PostPosted: Fri Sep 14, 2012 9:57 pm
cool, glad to hear it. and thanks for the info.
Users browsing this forum: Apple [Bot], Bing [Bot], GPT [Bot] and 57 guests
