 Post subject: Winstep + Java Application = grrrrr
PostPosted: Thu Sep 13, 2007 4:06 am
I use GanttProject for project management. It is an open source Java application that can be found here: http://ganttproject.biz/
When GanttProject is running Winstep fights with it. Ganttproject is always made to be first in the Z-order. So Any popup windows from GanttProject is sent behind the main window as well as any other application that I want to use at the time while GantProject is running and not minimized. This behavior happens on a timed cycle, about every 2-3 seconds so I'm guessing it has to do with a scanning/painting processes used by NS or WS.
I'm running the latest version of Java from Sun and GanttProject 2.0.4.
 Profile ICQ
PostPosted: Fri Sep 14, 2007 12:09 am
Ok, try adding the GrantProject task to the snapshot exclusion list. My guess is that this will fix the problem - but let me know how it went please.
PostPosted: Fri Sep 14, 2007 7:10 pm
That seems to have fixed it. If the problem pops up gain, I'll report it back here. Thanks!!
 Profile ICQ
PostPosted: Thu Sep 20, 2007 4:21 am
Ah, question, if you right click on any task on the NextSTART tasklist and select 'Customize Tasks', in the Snapshot Exclusion List section of the dialog that pops up, what exactly is GantProject listed as?
Thanks in advance,
PostPosted: Thu Sep 20, 2007 11:08 pm
GanttProject and it's a Window Title. The .exe Didn't work so I used the window title.
 Profile ICQ
PostPosted: Thu Sep 20, 2007 11:22 pm
Thanks! :D
Users browsing this forum: Amazon [Bot], Bing [Bot] and 96 guests
