 Post subject: clock question
PostPosted: Thu Jun 21, 2007 7:33 pm
Is there any way to make the clock chime on the hour for every hour (6 0 clock would chime 6 times )
and i see there is no way to check our hotmail accounts ... is this correct?
Thankz for any info
PostPosted: Thu Jun 21, 2007 7:58 pm
Sorry, the answer is no and no.
Regarding the clock chime, I might add this feature for the next release (e.g. set the number of 'chime repeats' to zero instead of 1 or above and Workshelf will chime on the hour for every hour).
As for Hotmail, Microsoft is the one to blame for this one. They provide no POP3 access to Hotmail accounts on purpose, and even premium accounts require a proprietary access method.
PostPosted: Thu Jun 21, 2007 8:10 pm
Thankz for the fast reply..
I will be looking forward to the next release, you have done a great job on this program, keep up the great work !
So do you have a date in mind on the next release ?
PostPosted: Fri Jun 22, 2007 4:09 am
First there will be a private beta - if you are a registered user just apply for the Beta Forums (instructions are in the FAQ).
I would say sometime this month. :D
