 Post subject: Awesome Program
PostPosted: Sat Jan 06, 2007 5:28 pm
Just found Winstep and it ROCKS!
However after picking a them, I can't figure out how to change the wallpaper. I checked the forum and it said there is a help manual but I can't even find that. I have a NextStep help manual and a WorkShelf manual but none for Winstep. Am I just plain dumb or what. :P
 Post subject: Awesome Programs
PostPosted: Sat Jan 06, 2007 11:13 pm
Winstep is a suite of programs - comprising Nextstep. Workshelf and Nexus (which is part of Workshelf). So you have the user manuals. Changing the wallpaper is easy - just change it as normal through Display Properties on Control Panels. There's and option to save wallpapers as you save themes (which I always forget about) in the preferences if you need to associate a wallpaper with a specific theme, and since wallpapers are saved with themes then its likely to change if you change a theme.
You are right though - awesome programs.
Pete
Users browsing this forum: Amazon [Bot], GPT [Bot], winstep and 69 guests
