 Post subject: Menu behavior in Workshelf
PostPosted: Thu Nov 30, 2006 1:28 am
Hi gang,
Here's one that has be baffled. I'm using the Brista NS/WS theme. By default the theme slides menus out left-to-right, and you must click a menu item in order for a submenu to appear.
Via the NS config, I changed that to my preferred behavior: fade-in menu, and mouseover to automaticallly display submenues.
However, the menus in WS (right-clicking an icon, right-clicking blank WS area, display the same old behavior of slideing left to right and requiring a mouseclick (except oddly enough the Tasks shelf, which display menus by sliding them bottom to top).
I can find no WS setting to allow me to change the theme's menu behavior like I can in NS. Am I overlooking something?
PostPosted: Thu Nov 30, 2006 1:56 am
Ah, I know what it is. Go to the Themes Manager tab in WorkShelf Prefs. Now click on the Theme Options button. In the Menus section, select 'Use Current NextSTART Theme'.
That *ought* to work. :D
Alternatively, go to the Themes Manager tab in NextSTART and re-save the Brisa theme.
PostPosted: Thu Nov 30, 2006 2:20 am
Thanks, Jorge! That did the trick.
Users browsing this forum: Amazon [Bot], Apple [Bot] and 51 guests
