 Post subject: Large Icon Problems
PostPosted: Wed Jun 09, 2004 12:07 am
Hi. I'm having problems getting large icons (48 *48) to work properly. I'm running Win XP and have large icons turned on in the windows dialogue box.
I guess it's best if i give an example of the problem. I'm putting HotSpot 'buttons' on the desktop. I have one for 'My Computer', 'My Documents', 'Recycle Bin', etc.
The hotspots work perfectly but some of the icons are not using the nice high quality large icons that windows provides. When setting up the icons I'm using the correct icon file, for example:
C:\WINDOWS\system32\SHELL32.dll
or C:\WINDOWS\explerer.exe
The 'My Computer' one works perfectly, but the recycle one is very jagged. When I check the correct icon paths in explorer they are correct.
Anyone have a solution to this? It's the only thing that's annoying my about the program.
Thanks for your help.
PostPosted: Mon Jun 14, 2004 9:33 pm
If you have XP set to display 'large icons' you shouldn't have a problem.
Any chance you can post a screenshot here with the Windows Display Properties dialog open (showing the icon size settings), the hotspot button icon visible as well as the hotspot button properties dialog?
Thanks,
Users browsing this forum: Apple [Bot] and 18 guests
