 Post subject: hotkey to bring modules to front
PostPosted: Tue Sep 12, 2006 4:11 pm
I would like to have my modules like the clock, come to the foreground with a hotkey command. Any help would be appreciated.
Paul
PostPosted: Tue Sep 12, 2006 6:04 pm
Working on it! :D
PostPosted: Tue Sep 12, 2006 6:18 pm
Ah, forgot to add: if you set the z-order of desktop modules to 'Normal (linked to shelf)' then they come forward whenever you bump the screen edge to raise the shelf or click on any other module that is also linked to the shelf's z-order.
 Post subject: Saw that
PostPosted: Tue Sep 12, 2006 10:43 pm
Use 2 screens and would love just to hit a key command to check out time and other stats. I like the new Xtreme, especially the snapshots on the tasklist.
Paul
PostPosted: Tue Sep 12, 2006 10:58 pm
Glad to know. And have you already noticed that you can move task tiles around and position them anywhere you want on the tasklist? Very useful too! :D
By the way, are you a registered Winstep user, Paul? If so, send me an email to support@winstep.net with the name or email address you registered under so I can add you to the Winstep Beta forums - just released a private alpha preview of the mythical NeXus (the dock component of the Winstep suite of applications) and the URL is available in there.
Users browsing this forum: Amazon [Bot], Majestic-12 [Bot] and 43 guests
