 Post subject: Font camel case problems in menus
PostPosted: Tue Jun 01, 2004 8:06 pm
I want to define a menu item "IE" and "mIRC", yet these come out as "Ie" and "MIRC" respectively in the display. When I go to edit the properties or edit them in the menu editor they are entered correctly- it's only in the menu display that they show up incorrectly.
PostPosted: Wed Jun 02, 2004 2:07 pm
Open NextSTART Preferences and navigate to the Menu Preferences tab. Now Click on the Menu Button Skinning Preferences button (the one with a magnifying glass over the menu) and in the Button Text section set the Text Style to 'Normal'.
Please note that this is a theme-dependent setting, i.e.; it's up to the theme author to specify the text style displayed on the menus and this setting will therefore change when you apply a new theme.
Users browsing this forum: Amazon [Bot], winstep and 135 guests
