 Post subject: Can't change label font
PostPosted: Fri May 04, 2012 8:08 am
Hello,
I would like to change label font behind icons in shelf i've found a setting in préférence
but it doesn't work for me, someone can help me ?
 Post subject: Re: Can't change label font
PostPosted: Fri May 04, 2012 8:59 am
That's only for when you set the number of text lines for icon labels in the Shelf to 'None'. When you do that, the label will appear outside the Shelf when you hover the icon, just like it does in a dock, and you can control the font of that label using that setting.
Otherwise, the labels of icons *inside* the Shelf is theme dependent. You can still change them *for that theme* by opening WorkShelf Preferences, going to the Themes tab, clicking the 'Customize' button, and changing the font used for 'Shelf Icons'.
PostPosted: Fri May 04, 2012 9:22 am
Thanks it's ok
Users browsing this forum: GPT [Bot], Majestic-12 [Bot] and 39 guests
