 Post subject: Task icons
PostPosted: Tue Jul 11, 2006 11:11 pm
Jorge...
I am running the Nextstep skin, and my task list icons are all up top... can I force them to be at the bottom of the screen? I know I could once upon a time, but I cannot ind the option
thanks
paul
PostPosted: Wed Jul 12, 2006 4:05 am
Hmmmm.... How about left clicking and dragging the tasklist to the position you want it to be?
PostPosted: Wed Jul 12, 2006 3:09 pm
Now, I know I can do that! :D
I found what I needed, the options had been moved to the "Floating tasklist" section.
PostPosted: Thu Jul 13, 2006 8:26 am
Which makes sense, no? :wink:
PostPosted: Thu Jul 13, 2006 3:20 pm
I must sheepishly say...yes it does...
:D
