 Post subject: Sub-Docks justification change in 12.02.1037
PostPosted: Tue Apr 10, 2012 1:12 pm
I use the Dock program and just updated to 12.02.1037. Before the update when I clicked on a sub-dock it would open left justified to the icon I hoovered over. To clarify the sub-dock's left most item would open immediately below the sub-dock icon on the main doc. Now the sub-dock opens center justified. Is there a setting I can use to change this back to left justified. I do not see any settings under Dock Properties to control this.
 Post subject: Re: Sub-Docks justification change in 12.02.1037
PostPosted: Tue Apr 10, 2012 2:25 pm
Behavior was changed. You can find more information in this post HERE. :D
PostPosted: Tue Apr 10, 2012 5:05 pm
Thanks for the feedback. I agree with the person posting the issue before me, not a great change, liked it better the way it was before.
PostPosted: Tue Apr 10, 2012 5:41 pm
You like it better as it was *or* you got used to it being like that and now you simply resent having to change? :wink:
I hope you agree it makes as lot more sense the way it is now. :D
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 76 guests
