 Post subject: work shelf
PostPosted: Sun Apr 08, 2012 10:55 am
Hi. I have just started using the demo, and added some items to the workshelf tabs - However now when I try to add a shortcut, a RED disable icon appears. Is there a checkbox that I have clicked accidentally preventing new shortcuts?
 Post subject: Re: work shelf
PostPosted: Sun Apr 08, 2012 6:34 pm
Maybe. Open the Shelf Properties dialog, then go to the Behavior tab. Is 'Lock icons and prevent them from being dragged' selected? If so, that's the problem.
If not, what tab type are you trying to drop shortcuts into? Not all tab types are the same, some display Shell virtual folders like Control Panel and, as it happens with the Windows Control Panel, the contents cannot be modified.
PostPosted: Mon Apr 09, 2012 9:01 am
Yes that was the problem, thanks for your help.
8)
Users browsing this forum: Amazon [Bot], Apple [Bot] and 92 guests
