 Post subject: Don't use the registry
PostPosted: Sun Jun 11, 2006 1:17 am
Here's a bit of history.
In the early 90's Microsoft issues a technote discussing the use of the registry. It said the registry should not be used to store applicaiton/user settings. It recommended an application should make an entry indicating it's location in the file system and store it's application/user settings in ini/config files (user settings in the users profile directory). Of course everyone ignored that fine advice most especially Microsoft (Office team). The technote was withdrawn (you can't find it anymore) and we end up with the mess that is the registry today. Thankfully MS are moving away from it with .NET.
Anyway, can I please request that you move Winstep settings to appropriate config (text) files.
e.g.
c:\Program Files\WinStep\ws.config (ini, whatever)
C:\Documents and Settings\bruce\Application Data\WinStep\..
It would makes it so much easier move (partial) setups between machines.
ta
bruce
PostPosted: Mon Jun 12, 2006 12:53 am
oops! meant to put in wishlist.
Anyway, for the above reason I find it much easier to use Folder shelfs than regular shelfs since I can copy the bits of the file system I want very easily.
PostPosted: Mon Jun 12, 2006 1:26 am
That's why you have Backup and Restore buttons in the Global Preferences panel of both applications, which saves settings to, and restores settings from, files.
Using the Windows Registry is a LOT faster (and safer) than handling INI files with thousands of individual entries.
PostPosted: Sun Jul 02, 2006 8:36 pm
Is this dependant on the size of the registry...or the amount of shortcuts on the menu(s) or shelf(ves)? The reason I ask is that it takes 18 seconds here to delete a shortcut from a shelf and 20 seconds to add one. I just timed it. To me, that's painfully slow when shelf cleaning time comes.[/quote]
James Senick
Stamp Collecting Store
PostPosted: Sun Jul 02, 2006 9:16 pm
Hmmm... It takes considerably less time here (like 4 seconds to add a shortcut, and it shows up on the shelf immediately, and another 4 seconds to delete it). My guess is that it depends on the number of shortcuts you have on Regular shelves.
I'll see what I can do to vastly improve this, since, given your example, it can trully become a problem if you have lots of shelf items (currently I'm saving the whole shelf contents - I should be able to dramatically cut down times if I only add/delete the single entry).
PostPosted: Tue Jul 04, 2006 11:35 pm
James...
I've implemented a 'delayed' save technique. Some programs only save their settings on exit, but I find this too dangerous - if the application crashes for some reason, you lose all the changes that were made in that session.
So, besides making sure data is saved on exit, what I do is wait until WorkShelf has been idle for some time - and then save. :D
Needless to say, adding and deleting stuff from the shelf now happens nearly instantaneously - quite a dramatic effect if you have lots of shelf items.
PostPosted: Wed Jul 05, 2006 5:31 pm
Great! Thanks. I have a ton of shelf items.
James Senick
Users browsing this forum: Amazon [Bot], Apple [Bot] and 54 guests
