 Post subject: Applying themes
PostPosted: Sun Apr 01, 2012 4:43 am
Hi
1st of all, I love this program! (Winstep Xtreme).
I do have an issue however. The bottom bar (Nextstart) when I click on the themes section, and apply a theme, the theme applies except for the Nextstart bar.
I have to right click on properties and choose from the theme list. This has never been the case before. Am I missing a certain setting?
Thank you in advance.
 Post subject: Re: Applying themes
PostPosted: Sun Apr 01, 2012 6:40 am
Devil is in the details...
What exactly are you calling the Themes section? There are many places you can apply a theme from, not to mention that you can do that from either WorkShelf or NextSTART.
Anyway, I would start by making sure theme integration between applications is enabled: open NextSTART Preferences, go to the Themes tab, click on the Advanced button, make sure Theme Integration is enabled.
PostPosted: Sun Apr 01, 2012 6:55 am
Hi
I meant the tab "Themes" which is next to quick launch and tasks. I did follow your directions and that option was checked. I cleared it and checked it again. I believe that this first started since the last update. I'll keep my eye on it though.
Thank you.
PostPosted: Sun Apr 01, 2012 11:50 am
Working fine here.
What happens if you change the theme via the themes tab of NextSTART's Preferences?
Users browsing this forum: Amazon [Bot], Majestic-12 [Bot] and 48 guests
