 Post subject: Bug
PostPosted: Fri Mar 30, 2012 2:26 pm
Hello Everyone.
To Winstep: Thank-you for your very active and continued work!
I have nailed down the bug that has been bothering me for ages.
If Microsoft Windows has "hide extensions for known file types" checked and there is a programname.exe and there is a programname.ini in the same folder; when viewing a folder as a menu in Winstep, it hides the programname.exe as if it does not exist.
For example: My CCleaner folder has the CCleaner.exe and CCleaner.ini.
I can replicate the bug in Winstep Extreme and in the Winstep Nexus Dock, any version from 10.x to 12.2
I hope we can finally get this bug fixed.
Thank-you!
If you want screen shots... I've got screen shots.
If you want a video capture... sure.
Bug #2: Sub Docks & Z-order
When I bring up a sub menu in Winstep extreme, or when I click on the weather module in Nexus... and I have windows open. The menu or weather bar (the weather icons need to be WAAAAY bigger, btw) pops up behind current windows.
Winstep is set to be always below other windows... so I can see why it would do this, but these need to be exceptions. When I bump my mouse to the bottom of the screen, the dock jumps to the top but the sub menu and the dock fall back behind when clicked. The sub-dock is unusable.
again:
Bug #3 Lost Recycle bin icon.
This has also been bothering me but I can live with it...
When I backup Winstep Nexus configurations settings, the restore feature seems to work fine.
IF I have a custom icon used for the recycle bin and I use that backup.wbk to restore the settings on another computer, everything restores except the custom recycle bin icon, which resets to default. So I have to grab the HKCU\Software\WinSTEP2000 and restore that as well, then the custom icon is restored.
 Post subject: Re: Bug
PostPosted: Tue Apr 10, 2012 2:18 pm
Bump.
Just so I don't forget about this. :D
Users browsing this forum: Google [Bot] and 49 guests
