 Post subject: Sub-docks
PostPosted: Tue Mar 27, 2012 4:08 pm
Jorge,
Why does the sub-dock hide behind the dock when I have the magnify option turned on? When I mouseover the icon, the sub-dock bashfully hides behind the parent (I used to be the same way). z-level? See below:
Thanks,
Grouch
Windows 10 Pro[x64]
Nexus Ultimate 20.10.1154
Antivirus: Windows Defender
 Post subject: Re: Sub-docks
PostPosted: Tue Mar 27, 2012 4:13 pm
Z-Order problems are a pain in the royal behind to get right. Ask any developer. :)
Anyway, what is the parent dock's z-order set to (Dock Properties -> Position tab)?
Are you sure you're running v12.2? There used to be a similar problem but it was solved by making the window of the parent dock the owner of the sub-dock window. I can't reproduce that here, for instance.
Also, did you do a 'Show Desktop' before taking that screenshot?
PostPosted: Tue Mar 27, 2012 5:34 pm
Jorge,
Position:
Yes, of course I'm running 12.2. :lol:
No, I've never used "Show Desktop". I was on the Desktop.
Thanks,
Grouch
<edit>
I see, when I'm in an app, the sub-dock behaves as I would expect it to. When I'm on the desktop is when it misbehaves.
</edit>
Windows 10 Pro[x64]
PostPosted: Wed Mar 28, 2012 8:56 pm
Jorge,
Problem resolved. Thanks. Looking good!
Thanks,
Grouch
<edit>
Oops! I spoke too soon. It still behaves badly. It worked once, but returned to its evil ways.
</edit>
Windows 10 Pro[x64]
PostPosted: Thu Mar 29, 2012 12:17 am
Jorge,
Maybe this will give you a clue. If I exit an app and I'm at the desktop, if I click on the sub-dock's icon, the sub-dock will extend down in front of the parent dock (as expected). But, if I click on the desktop first, the sub-dock will extend behind the parent dock. I assume that would be sort of like using your "Show Desktop" command.
Hope that helps.
Thanks,
Grouch
Windows 10 Pro[x64]
Users browsing this forum: Majestic-12 [Bot] and 40 guests
