 Post subject: How can i get rid of Hot spot 0
PostPosted: Fri Mar 23, 2012 9:55 pm
There is this module on my desktop that appeared it square windwo with one icon that looks like a blue folder when its for nextstart start menu. I tried deleting it and gives me error saying cannot delete hotspot 0. I have newest version of winstep extreme.
 Post subject: Re: How can i get rid of Hot spot 0
PostPosted: Fri Mar 23, 2012 10:04 pm
You do understand that hotspot 0 normally gives you access to the main NextSTART menu, no?
Anyway, if you know what you are doing, you can 'get rid of it' by opening NextSTART Preferences, going to the Hotspots tab and then either
a) Disable the hotspot by clearing the check box.
b) Edit it and set the activation method to keyboard only, for instance.
PostPosted: Sun Mar 25, 2012 9:18 am
Yes I know but i only want to get it off my desktop and not on my docks or the nexstart bar. For somereason there is a module on my desktop that appeared and thats what i want to remove not the function on bars and docks. I made a mistake of making another post about this sorry bout that.
Users browsing this forum: GPT [Bot], Majestic-12 [Bot] and 36 guests
