 Post subject: problems with applications active and reserve edge of screen
PostPosted: Sun Mar 18, 2012 6:39 pm
hello
nexus has a problem when showing active applications and the option to reserve the edge of screen, when there are many icons in the dock, the reserve from the edge of screen changes to make more room for new icons and this makes it the nexus ralentize and windows, please correct this problem. thanks
 Post subject: Re: problems with applications active and reserve edge of sc
PostPosted: Sun Mar 18, 2012 6:47 pm
Have you tried the latest beta of v12.2, which you can find HERE, to see if this problem has already been corrected?
If not, please try it then let me know.
Thanks,
PostPosted: Tue Mar 20, 2012 2:23 am
hello
download the beta and the problem persists ... more applications open when the dock is smaller and the reservation of the screen edge and this also causes the lock open windows along with the dock and windows, there is a way to fix it? can be static reserve size screen edge?. Using Windows 7 Ultimate x64, screen resolution 1366 x 768
Thank you.
PostPosted: Tue Mar 20, 2012 2:46 am
If you were running Winstep Xtreme you would be able to solve this problem via NextSTART's 'static' reserve screen space feature. Under Nexus Ultimate/Xtreme you could also work-around the problem by using more than one dock or categorizing programs into sub-docks.
Unfortunately it's too late to include a fix in v12.2, which is just about to be officially released.
I'll look into this anyway, but to make it absolutely clear I understand what is going on: your dock has so many icons that it can't use the icon size you specified without extending off-screen - in order to fit on the screen, the icon size is automatically reduced, and, when this happens, the reserved screen area changes.
That's what is happening, right?
If so, another way to alleviate the problem is by setting a smaller icon size, so Nexus doesn't need to keep automatically reducing it in order to fit on the available screen space.
PostPosted: Tue Mar 20, 2012 3:06 am
is exactly what happens ... since all the icons or dock is smaller to make room for new active application icons and change the subject from the edge of screen, while the size of the windows ... and that causes some conflict, well thank you very much for your reply, I hope is fixed in the next version, I'm about to buy nexus ultimate but if I had more features or new features certainly would buy all, sorry for my English .. . thank you very much George! :)
Greetings.
Users browsing this forum: Apple [Bot] and 65 guests
